-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Turn signal (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/72392-turn-signal.html)
jenmcd 06-24-2002 09:46 AM
Turn signal
My turn signals work, however...the turn signal dash light is doing something weird. When I click the stalk for a right turn the dash light blinks normally. When I use the left signal the dash light blinks just once then quits. Like I said the exterior lights (turn signals) function normally. Any ideas??
Thanks in advance
Keith
JmuRiz 06-24-2002 09:59 AM
Mine has a simmilar problem, I attribute mine to the aftermarket steering wheel though, the triggers don't work on the self cancelation. But as long as they work on the outside I'm not too worried.
Nathan
ruddyboys 06-24-2002 10:42 AM
On my 74 the outsides work fine and the gauge light goes on but doesn't blink.
Jim Savage 06-24-2002 01:42 PM
My turn signals worked outside but the light inside would flash
bright the first time and then both of the interior turn signal
lights would flash at the same time but real dim. A used
turn signal relay from a swap meet that I paid $2 for fixed mine.
Jim
Barber Dave 06-24-2002 04:16 PM
turn signals
Is there a rebuild for turn signals that won't cancel, same right or left , they work ok other than that. thanks DaveSmileWavy
JRust 06-24-2002 04:23 PM
Hey Dave I've heard the turn signal assembly of a 924 will work. Seems like I read that on some previous post. You might want to do a search for that. How do those lugs I sent you look on your car. Post a pic so we can all see your little beauty:D
24flys 06-24-2002 06:07 PM
are you sure the left turn signal bulb isn't blown out. turn signals will sometimes act funny if a bulb is blown. if that ain't it, I'd try a new turn signal switch, but I'm no expert. Mine wouldn't work at all and I replaced everything and it turned out to be the turn signal switch itself. good luck
24 flys
Clay Perrine 06-25-2002 05:07 AM
The turn signals on a 74 use a single indicator that is triggered by contacts in the top of the turn signal relay. The relay is dependent on the proper loading to make the indicator light flash. If one boub is out, the light in the dash won't work. If one side is working correctly and the other is not, it will not be the relay. If your tail light is wired incorrectly, it will look like it's working OK from the outside, but there won't be the proper loading on the circuit, and the indicator won't work.
Things to check.
1. Make sure that you have the correct bulbs in both the front and rear turn signals.
2. Check the wiring on the turn signal housings. Make sure the correct bulb is flashing.
