Eat-um-up's Avatar
Send a message via ICQ to Eat-um-up Send a message via AIM to Eat-um-up
blinky break light help
i lost pressure in my master cylender and put more fluid in it and did the whole deal.. i read on an earlier post that there was a switch on the master cylender to press to make that stupid light stop blinking.. well i cant find any such switch. so how do i turn it off.. and my car does not have a e-brake switch. or at least i cant find it
72' 914
Old 07-16-2002, 01:53 PM
John Rogers's Avatar
The reset button is on the switch that is screwed into the master cylinder, IF it has a reset switch? I have seen several, mine included that did not have the reset button. The emergency brake switch is in the corner at the box cross- reenforcement under the e-brake handle and you might have to remove the seat to see it. I have seen a couple of cars that had a really nice buildup of dirt, carpet pieces, etc that covered it up completely. Good luck.
Old 07-16-2002, 02:27 PM
Eat-um-up's Avatar
in the previous poast someone said that you could reset the switch manually.. how do you do that?
72' 914
Old 07-17-2002, 01:09 PM
Paul_Heery's Avatar
http://www.pelicanparts.com/914/914QA/914Q_brakes_e_light.htm
Old 07-17-2002, 02:09 PM
