-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   R there any 4 to 5 Lug adapters so I can put on Chevy rimz? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/747937-r-there-any-4-5-lug-adapters-so-i-can-put-chevy-rimz.html)
Playa76911S 05-03-2013 10:53 AM
I gotta 914 project thats gittin a corvette motor conversion an flairs instaled so I can fit some 22" Rimz. Gotta put all dat power down on tha street! Tha flairs R done but I gotta work on fittin tha lambo doorz.
Problem iz tho...tha lugs R 4 bolt an the Rimz that I wanna git R off a 5 lug '03 Impala.
Do they make a adapter so I can run Chevy Rimz?
http://forums.pelicanparts.com/uploa...1367603273.jpg
http://forums.pelicanparts.com/uploa...1367603504.jpg
Bob Kontak 05-03-2013 12:28 PM
Doors look fine. Perhaps you are being too fussy?
Edit: I also see at least five holes in that fancy wheel.
Dave at Pelican Parts 05-03-2013 03:14 PM
I don't believe anyone does. Definitely not ones I would ever use, at least.
--DD
Cairo94507 05-03-2013 08:58 PM
Good luck with that project....playa. The lambo doors are the way to go if you are a real deal baller.
black73 05-04-2013 08:26 AM
Since your putting a Chevy motor in it, you should stick with that El Camino look in the rear trunk area.
Bob Kontak 05-04-2013 12:42 PM
He could hinge the rear light bracket for a tailgate.
larrym 05-28-2013 12:12 PM
just search eBay with 4x"target size" - lots of high quality adapters out there and they are used by hotrodders all the time - just don't plan to race on them unless they are steel instead of alum - ther is a guy in SoCal who makes steel adapts - expensive
djpateman 06-12-2013 12:06 PM
What do you need adapters for, fer heavnz sake, just crazy glue the rims to the rotors. But you need to put on a 15" lift kit first.
