blinky break light help
i lost pressure in my master cylender and put more fluid in it and did the whole deal.. i read on an earlier post that there was a switch on the master cylender to press to make that stupid light stop blinking.. well i cant find any such switch. so how do i turn it off.. and my car does not have a e-brake switch. or at least i cant find it
72' 914 |
The reset button is on the switch that is screwed into the master cylinder, IF it has a reset switch? I have seen several, mine included that did not have the reset button. The emergency brake switch is in the corner at the box cross- reenforcement under the e-brake handle and you might have to remove the seat to see it. I have seen a couple of cars that had a really nice buildup of dirt, carpet pieces, etc that covered it up completely. Good luck.
in the previous poast someone said that you could reset the switch manually.. how do you do that?
72' 914 |
