Carb conversion procedures
I know this topic has been discussed, and I did do a search for it, but to no avail. Does anyone have the step by step prcedures for converting from FI to carbs. My friend is doing the conversion and is having some electrical problems. He is specifically looking for the wiring diagram for the conversion. He hooked it all up and tried to fire it and he smoked the condenser. I told him to check the connection on the coil, but he said that was right. I'm going over there tonight to help him and would like to have some info in my back pocket.
TIA
Randy Davidson
2011 Chevy Silverado (The Hauler)
1984 911 Carrera summer daily driver
Old 07-19-2002, 05:59 AM
Rouser's Avatar
Send a message via ICQ to Rouser Send a message via AIM to Rouser
There aren't any "step-by-step" procedures for converting a FI system to carbs, since most installations are:
  • Hodge-podged-cobbled-together,
    No two installs are the same (single 2-barrel, dual 1-barrel, dual 2-barrel), and
    Most installs are a "Rip THIS out, and THIS, and THIS, and ...
If you're smoking condensors like popcorn, than yep, the distributor (whatever distributor it is you're using i.e. stock or 009/050) and/or coil is wired improperly.
A Haynes manual (You DO have a manual, right?) should provide the info you need.
Rouser!
Old 07-19-2002, 01:59 PM
Brad Roberts's Avatar
He hooked the positive wire to the negative side of the coil.
How else do you fry things like that ?
B << runs 050 dizzys with electronic ignition when carbed.
Old 07-19-2002, 02:33 PM
