-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   How to tell if thermostat is bad (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/750841-how-tell-if-thermostat-bad.html)
andreic 05-19-2013 10:33 AM
The thermostat cable in my 1975 914 1.8L was broken, so I set out to fix it. In the process I took the thermostat out and decided to check it, and now I can't figure out how to tell if it is good or bad.
I measured its length between holding it in ice and putting it in boiling water. The difference was about 6mm (1/4"). To me this seems too little, so I suspect the thermostat is broken. Also, at room temperature I can compress it by hand for about 1/2".
What do the members here say, is it broken or not? If it is broken, where can I find a replacement?
Thank you,
Andrei.
luskesq 05-19-2013 12:06 PM
I have a good one on my bench waiting for install. Cold, you can't compress. After a few minutes in 150-160 degree (f), it should expand to 46 mm in length (per Haynes). Post a wtb in the classifieds.
Keith
andreic 05-19-2013 12:11 PM
Thanks, Keith. Where did you get your good one? I'll post a wtb.
luskesq 05-19-2013 04:24 PM
Was fortunate because on a similar post a member chimed in that he had one (perhaps more) that I pm'd. Maybe you'll be as lucky. Good luck!
Keith
Hcarraro 05-20-2013 02:40 PM
Matt at Retro Automotive has them. I saw a like new one for $65.00 with a buy it now.
Henry
Porsche 911 912 Parts 1965-89, Porsche 924 Parts items in RETRO AUTOMOTIVE PRODUCTS store on eBay!
luskesq 05-20-2013 04:14 PM
I also happened to come across AwesomePowdercoat.com (no connection & haven't dealt with them) who was mentioned on a different Board. Presumably they have the correct temp thermostat although it is more expensive that Retro Automotive.
Keith
andreic 05-21-2013 08:05 AM
Thanks Henry, I just bought one from Retro.
