engine swap quest.
when i switch from f.i. to a carbed motor(no ranting i'm saving the f.i. motor intact) is it as straight forward as it seems? appropriate wires to coil, fuel pump change, and the starter wires?i presently have a 009(i know) but i also have a distributor from a 1.8. does anybody have any thoughts about plumbing the webers to utilize the vaccum advance and would the advance curve support the carbed motor. the motor is nothing fancy, a poorly advised rebuild with a hydro cam.
kevin
Old 07-22-2002, 04:29 PM
JRust's Avatar
Hey Kevin are you gonna part with the 2.0? I'm considering a Big Four & could use a good core!
Jamie Rust
73' 2.0
PacificNW914 club member
Old 07-22-2002, 07:56 PM
from what i know the 1.8 dizzy is the best for carbs but i dont think the vac advance is all that nessessary i left mine unhooked after tune up and did not notice a difference
it only does anything on a fi motor just off idle after that it does nothing
scott thacher
75 914 with 2.5 l 98 suby engine on the road
Old 07-22-2002, 08:04 PM
sorry jamie it's like money in the bank. until i have enough dough to break it down i'm going to leave it whole, pull the plugs squirt a little oil in the cylinders and turn it over by hand once in a while.
but what you might do is contact dave ellison at triad west. he's got more stuff than i can discribe. i'm under a bit of a dead line to try and make it to the gathering next month.i'm dropping the the engine tomorrow night and plan on replacing a few cables and bushings while it's in the air.
kevin
Old 07-22-2002, 08:27 PM
