-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   original keys (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/76201-original-keys.html)
marksgerman914 07-31-2002 10:30 PM
original keys
My 74 914 2.0 has a red key for the doors and trunk. But has a v.w. key with a black circle head with vw in the center. Are these the correct keys? Also it originaly had a leather storage pouch attached to the keys. I beleve it was red. Does anyone have one of the pouches?
mejulihn 08-01-2002 07:01 AM
Mark,
Originally, the red key would have been a "valet" key and only keyed to the ignition. A nearly-identical black key was keyed to the ignition, doors, glove box and both trunks. I think they were Porsche key blanks and not VW.
maf 914 08-01-2002 08:56 AM
That is correct, the original keys were Porsche black and red (valet). Key blanks are still available if you want to have some made.
Mike
rockaria 08-01-2002 09:17 AM
My 75 1.8 had the exact same key situation. I noticed that the VW key is Different from the Porsche key totally ( I could not buy a Porsche key and cut it, and the doors would not fit the VW key). I know the PO replaced the ignition switch tumbler. So I assume he bought a cheap VW one that would fit for that year.
I know the 75-76 Steering hub was a direct change with the 924 and a VW, maybe they came with two keys? I doublt it. My solution was to install a 1972 914 Steering hub ($40 used - Tumbler hub switches and everything) with tumbler and Porsche key (Direct swap if you do not have intermintant wipers), and then re-arrange the Door, Trunk, andall tumblers to match the new ignition key, then I had 3 black and 2 red Porsche keys cut.
Now my car has 1 Porsche key that works great on everything. My wife has a key and there are keys in the safe for when I need them.
I hope this helps,
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
