Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
ruddyboys's Avatar
grant piston rings
I found a set of grant piston rings under the spare tire. I was going to put new rings on my car next week and was wondering if these are a decent brand.
Old 08-01-2002, 03:44 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Senior Member
A well known manufacture....from the 50/60s.....
that's last century ....gud stuff back then, for American iron.
I didn't know they were still in biddness. How long have the rings been under that spare?
JPIII
Early Boxster
Old 08-01-2002, 10:44 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Grant rings don't seem to have the best rep necessarily. A search on the Shoptalk Type 4um pops up a note from Raby about Grant rings having too much end gap out of the box...
Deves seem to be good.
--DD
Old 08-01-2002, 01:47 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Deves are great, throw those grants as far as you can out of sight, they are good on some engines, but not type IVs/
Jake Raby
Owner, Raby's Aircooled Technology
www.aircooledtechnology.com
www.massivetype4.com
Old 08-01-2002, 07:53 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Thumbs down
I had a set of Grant rings that came with my P/C set... They were wayyyyy out of whack, all too large.
Sad part is, from that whole pack, all I am using from it are the pistons. It would have been cheaper just to buy the pistons seperate.
Anyone want a set of brand new 96mm jugs?
Later,
Tom
Old 08-02-2002, 10:49 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
ruddyboys's Avatar
A few other people I talked to (1 restores MGs for a living) said grant are no good, thats probably why they were never installed by PO. Monday I will be odering from PP.
Old 08-04-2002, 07:05 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
COLDBASS's Avatar
ruddyboys,
Good choice, I listened to Jake and the others on STF and I am glad I did. I had Deves installed on my 96 JEs...my rebuild went smooth, and the motor is running strong...
Good Luck
Bob
Old 08-04-2002, 05:36 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
Mark Stephens sold them with his kits and look at him now.
I bought one of his 2056 top end kits just before he went out of business and have a real strong track car w/ grant rings. His head work was the ticket, unshrouding, port and polish.
Better to too much end gap than not enough.
Doug
Old 08-05-2002, 09:19 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
norustscott's Avatar
on the subject of rings
I unfortunatly did not get the memo on type 4 ring selection and I am paying for it now. I a installed the total seal gapless second ring on a set of stock euro spec KS p and c's. I have 2700 miles on the engine and it still will puff smoke @ idle during a long traffic light.
This goes against all of my previous type 1 experience. Not sure why Type 4's do not like the TS rings?
Total Seal said I should give it 3k to fully seat? I think I will be replacing them by 5K.
BTW. I have great/even compression. 145lbs+- 2lbs engine runs nice and cool. 24-26 mpg.
This is my data on the Total Seal issue. I have to wonder, Has anyone had Total seal rings to function and break in or is oil control @ the cylinder always an issue....????
Cheers,
Scott
1973 2.0l ivory 914
1962 sunroof bug
1966 std bug
1990 WE Vanagon CARAT
Old 08-05-2002, 10:05 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
I have had zero luck with total seals ina TIV engine on the street...They never seemed to ever break in....Also Greg @ FAT Performance has seen this as well.
A ring with too much end gap is terriable, crankcase pressure and burning oil is a huge problem......
It is Deves, or Hastings for me, and thats it, I have tried the others, they cost me time and money..
Jake Raby
Old 08-05-2002, 11:08 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
Jake,
Have you evered had them seat? Should I keep going or make the swap to the stock oem rings. OR swap to the deves? It is a totaly 100% stock engine. I want mpg/and longivity...?
Cheers,
Scott
1973 2.0l ivory 914
1962 sunroof bug
1966 std bug
Old 08-05-2002, 12:59 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
Got so disgusted with them in 3 engines that I tore them down and replaced with Deves.....ho chances there, they break in on my dyno in most cases.
Jake Raby
Old 08-05-2002, 01:15 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
Found this old thread and was wondering if Grant pistons rings are still not recommended.
The machinest sold me a set after I had by 94mm pistons and cylinders cleaned and honed.
The top ring gap measured 0.35mm and the 2nd ring gap measured 0.25mm.
Old 08-08-2012, 08:45 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #13 (permalink)
I don't think Grant has made piston rings since the 1970's. There is a reason Grant only sells cheap steering wheels now.
Old 08-09-2012, 04:12 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #14 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
