Prop valve AIR
You have to force air out of the proportioning valve, yes it does have the ability to hold air. I bleed the line into the valve. then have my boy pump up the brake a few times then keep pushing it to the floor as I loosen the rear brake caliper bleeders. You shoul be able to hear the piston shift iside the proportioning valve as pressure releases.
Old 08-03-2002, 10:45 AM
