-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   That is about what I am running (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/76418-about-what-i-am-running.html)
Joe Ricard 08-03-2002 11:51 AM
I did have Euro pistons but was forced to change over to U.S. spec. Sort of broke one. BUT I run 44IDF's SSI Bursch and a 290 duration 500 lift cam. Don't know how fast it will go but I did pull 5800 RPM in 5th gear and still had more umph to go.
Brad Roberts 08-03-2002 12:53 PM
Pretty crazy cam for a street car.
I think Webcam listed that cam as .512 lift.
If the valve springs can take it, that cam will pull to 6400 with no problem.
B
Joe Ricard 08-04-2002 05:34 PM
Yea !!!!
Well the car has dual valve springs. Let my knuckle head brother drive. I watched him tach out at 6K + in 3rd. and I didn't hear no valve float. He won't be in my car NO MORE!!!
P.O. started to build car for racing. I like to drive it to work:D
Brad Roberts 08-04-2002 07:05 PM
I have used that same combo in 914's in the past.
With a little bit of gas pedal and side stepping the clutch, it should "haze" a 195/50/15 with no problem.
Haze meaning .. light smoke with somebody watching.
Rev to 4500 and sidestep the clutch.
B
