Question moderate changes to a 1.8
In another post, I saw mention of making a 1.8 into a 1911 using flat-top 96mm piston/cyl asms. Can you retain the L-Jet with this change? Any need to bump the richness by faking the ECU or using 2.0l Bus injectors? This isn't that much smaller than the original 2.0; does anyone know how close it gets to the 100hp of the higher compression 2-liter engine?
Old 08-08-2002, 08:56 AM
mike mueller's Avatar
I ran this combo and I never had any problems. The car ran great.
No need to worry.
'73 914, 1.7, with Boxster transmission in the future?
Old 08-08-2002, 10:42 AM
Any idea what kind of power does it make over the stock (76hp) 1.8? Does it approach the performance of a stock 2.0?
Old 08-08-2002, 11:51 AM
I saw a while back Rolando Cruz referred to a European spec 1.8L with carbs that developed 85+ HP. It was his favorite engine of the 4 cylinders. Anyone know the details on that? Was it standard issue overseas? What's different? The cam I assume?
I like my '75 FI, but I also had a '74 1.8L with carbs that when tuned right really ran very strong. It was a PITA to keep tuned though.
Chris H.
'75 914 3.3
Old 08-08-2002, 12:15 PM
Ron Meier's Avatar
From what I think I remember reading - the "Euro" 1.8 was fitted with dual single barrel downdrafts and had a compression ration of 8.?:1. I don't remember if they were Solex or Webers. CB Performance has the setup (and probably others).
Don't know anything about the cam.
"Inventor - Blue Flame 914 Seat Heater"
"Yellow Rusty Cars Are Faster"
_____________________________
'70 2.5 (I'll never finish it - Somewhere over the rainbow.....,)
'73 2.0 (Just Not The Same)
'74 2.0 (Heartless & Lungless)
Old 08-08-2002, 06:05 PM
Brad Roberts's Avatar
Will,
This combo should yield around 90hp with some mild clean up on the exhaust ports.
The 1.8 had a breathing problem.
Put 2.0 heads on your 1.8 and watch it come alive.
The spark plug angle really really helps the 2.0 heads.
B
Old 08-08-2002, 08:05 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
8.6:1 compression, engine code "AN". Also used on some of the 411 or 412 cars. Dual single-throat 40mm Solexes (40 PDSIT, I think). The factory parts book calls it the "1.8V". Made 85 HP, DIN spec.
--DD
Old 08-11-2002, 07:57 PM
