Zeke's Avatar
One Inch in One Hour
I wasn't looking forward to this, but I want to run 225/50/15s on 8" rims if I can get them under there. So, with a BFH and some smoothing out,.........Flares! About an hour a side. Nasty work, if you ask me.
My FB page: https://tinyurl.com/OddJobFix
Antique and Collectibles Repair and Restoration
Old 08-09-2002, 09:08 PM
Brad Roberts's Avatar
Man,
YOU are crazy. Have we met ??
Its looks kinda cool.
B
Old 08-10-2002, 12:21 AM
Senior Member
Gotta agree, it IS a nasty job. I wuz only 56 when I did this.
I'm 57 now and don't do crazy $h!t no mo.
JPIII
Early Boxster
Old 08-10-2002, 01:36 AM
Milt and JP,
Nice work. It must be a little scary to start hammering away at the fenders like that. Oh no, what have I done! Once you start, there is no turning back! LOL
Mike
Old 08-10-2002, 04:54 AM
Zeke's Avatar
Looks a little better with the metal glaze on.
Oh, and the one hour per side deal passed about four hours ago.
Old 08-10-2002, 08:00 AM
And I thought fiberglass or welded on steel flares were the most popular means of achiving this look.
Thought about making a video? : )
Good work!!!!! Please post pics of the finished product with wheels/tires mounted.
John
'73 914
(Renegade V8 conversion)
Old 08-10-2002, 08:34 AM
Senior Member
OK.....
These are left and right. They are......ah.....similar
JPIII
Early Boxster
Old 08-10-2002, 03:02 PM
JP,
You need a bigger wheel chalk than that one.
I would hate to see that car role down the driveway and hit the Chebby truck.
Flares look great.
Innovation, not imitation.
B
Old 08-10-2002, 04:35 PM
Senior Member
No problem.....the truck is there to stop it ...........and since I now have a winch and a hard spot set into the floor, I kin winch the wreck back up into place.
Another great project in the making.
JPIII
Early Boxster
Old 08-10-2002, 05:45 PM
Zeke's Avatar
I'll be 57 in 20 days. I think there's a lot of crazy stuff ahead on this project. I'll learn......,maybe. I should change my signature to *Crazy Milt* per Brad. BTW, Brad, no we have not met in person, but I tried to buy a tub w/ rollcage from you last year.
Old 08-10-2002, 06:24 PM
David McLaughlin's Avatar
Porsche Crest
I just bought a set of 6&7x16 Fuchs for my car and had planned on mounting 205s in the front and 225s in the rear. I was guessing that a little persuation using the old baseball bat method was all I would need. Is all this work posted above really necessary? Maybe my tire choice is a little wide?
TIA,
1970 914/6 RustoMod
2015 Mercedes E400
Old 08-10-2002, 06:30 PM
We dont roll them anymore.
I pinch them. I take that inside lip and flatten it completely against the outside lip. With a hammer and dolly.
A 225/50/15 will fit. Kinda depends on the ride heigth.
B
Old 08-10-2002, 06:38 PM
Senior Member
I did a test fit with 225 50 15 on 7s...."before hammer".
No way, Jose.....at least on mine....almost made it on the pass side, but the clearance would have been zip...or less. Not even close on the drivers side. More negative camber would have helped, maybe. The Kuhmos were wider than the test tire.
I understand Hoosiers are wider yet.
JPIII
Early Boxster
Old 08-10-2002, 11:40 PM
Ron Meier's Avatar
NICE Job gentlemen.
Reminds me of the days in SCCA when you couldn't add anything and the "baseball bat roller" was the only method to cover those "Blue Streak Specials" (wow, I am old).
I wish the PO on my '70 shell had used the "pinch" method - he cut the lip off.
"Inventor - Blue Flame 914 Seat Heater"
"Yellow Rusty Cars Are Faster"
_____________________________
'70 2.5 (I'll never finish it - Somewhere over the rainbow.....,)
'73 2.0 (Just Not The Same)
'74 2.0 (Heartless & Lungless)
Old 08-11-2002, 09:16 AM
Senior Member
The SCCA still requires you to maintain the wheel opening shape (as viewed from the side)...both in track racing and in Solo II.....otherwise, it's off to the modified classes you go.
Kinda' limits ones options.
JPIII
Early Boxster
Old 08-11-2002, 10:16 AM
JmuRiz's Avatar
Another wheel question...
Does anyone think that I can fit 205's on a 16x7" rim in the stock rear fenders? I currently have 205's on 15x5.5 and it fits just fine, thanks for any input. Since most people selling 911 wheels sell them in 2-16x6 and 2-16x7 sets, I thought it'd be nice to know if they'd fit. Thanks fellas.
Nathan
'74 911 with '83 SC engine
'73 2.0 914 (2.7 /6 conversion in progress)
'64 356SC
'02 S6 Avant
'99.5 A4 2.8 / '65 Ducati Falcon 80
Old 08-11-2002, 11:17 AM
Nathan,
I was at Renegade Hybrids in May and saw Scott's 914 with 16 x 7 on all four cornerns without any evidence of fender rolling. Sorry but don't have his tire size.
There is also another of our readers (Craig) with a really clean yellow teener that carries 16's quite well using 205/45/16s. Perhaps he will share a pic or two with you. Craig actually rolled his lips a bit for proper fit but I'm sure you have heard that this varies from car to car and tire specs.
John
'73 914
Old 08-11-2002, 02:55 PM
i recently did a test fit of 16x6 with 205/55 comp t/a s and there was nooooooooo way they would work on my stock rear fenders. i don't think they would work even if i rolled the lips!!
doug
doug waters
70 914-6
dougwatersfotos.com
http://www.flickr.com/photos/dougwatersfotos/
Old 08-11-2002, 03:26 PM
si2t3m's Avatar
go figure...
225/50VR16 on 16x6 under stock fenders...
I have about juste a bit more than 1/4 of an inch between the lip and the tire.
Old 08-12-2002, 08:55 AM
Senior Member
I was using 205 50 16s at the rear. They fit fine with about 5/8 inch clearance on the pass side and 1/4 on the drivers side.
Since the 7s are an inch wider and 7/8 (or so ) is offset outward, the problem becomes obivious.
8s would be more better for the 225 tire. I'm semi looking for a pair (15 inch). They just might fit now (with some neg camber). If not, I still have a BFH
Your car is lookin' good, M-A. How's that 3.0 running? I hear you got top time for AX at that recent East Coast thingy. Wish I could have made it to uphold the 2.7Ls honor.
JPIII
Early Boxster
Old 08-12-2002, 09:28 AM
