kellzey's Avatar
3.0L engine - What's it worth?
1979 3.0L engine - still has CIS.
82K documented miles. Slight oil leak.
2 broken head studs. (Might as well plan on replacing them all).
No other mods to the engine. Runs well.
What's this engine worth?
Thanks,
Qarl
Old 08-12-2002, 04:30 PM
Jim Smolka's Avatar
To replace the heads studs is worth about 40 hrs at a shop.
Not cheap to fix. Then if you have to redo the valves, seats, cyl, etc... Also, how long has the engine been run w/broken head studs??
If you were to do it yourself, I would say the motor is worth low of $500 to a max of $1000 IMHO
It is much cheaper to find a good 3.0 or 3.2, than to rebuild a 3.0.
However, it is a fun project to rebuild a motor.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 08-12-2002, 05:15 PM
Brad Roberts's Avatar
Yep. I have to agree with Jim on this one.
Its a core engine. I dont care how it runs.
1500$ tops.
I have a brand new set fo Euro P+Cs for a 3.0
B
Old 08-12-2002, 11:04 PM
jabb's Avatar
If you can convience the seller its a core engine I do not think you will get it for less than $2000 if you do than you have a good deal.
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 08-13-2002, 03:38 AM
Serge914's Avatar
Did you see this one ?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1850120165&rd=1
Serge
1973 914 2.0 mostly track car
1984 Golf ( Wife car )
1996 Volvo 850 station ( Good family-men car )
Old 08-13-2002, 10:26 AM
I saw. I ran the numbers to see what a Canadian car would have.
It has the lower compression engine at 8.3:1
It does however have the larger intake and exhaust ports than the normal USA 3.0
This is a ROW car.
B
Old 08-13-2002, 10:32 AM
kellzey's Avatar
Canada is sort of far away from Florida...
But thanks!
Karl
Qarl
Old 08-13-2002, 10:47 AM
