Wiring Issue
I'm looking for a Little Orphan Annie decoder ring for the inputs to the dual relay on my '74 1.8L. The wiring diagrams all show numbers like 88d and 86c etc. but the marking on the plugs are 1 thru 9. Also somewhere I have acquired a harness for a '75 1.8L and the plug for the double relay is wired differently. I have broken wires that I need to repair and I'm confused.
Old 10-03-2013, 10:24 AM
Resident Electrician
Mike Bellis's Avatar
The numbers refer to the pins on the relay itself. Not the plug.
Current Project: 73 914, 1.8t, ~300hp, 930 Brakes, Roll Cage
Past Projects:
69 911, converted to C2 wide body cabriolet 3.2L
72 914, Ford 5.0L V8 EFI
Old 10-05-2013, 08:54 PM
