mike mueller's Avatar
8" wide rims+225's and NO flares on the back...
Did some test fitting last night with an extra set of late model 911 rims i have sitting around in the garage.
These have a 52mm offset.
The front fit fine (6" rim) it would need a one inch spacer to look right, it is tucked in too far. A 7" rim or even an 8" rim up front would work as well.
For the rear, the tire hit the trailing arm and the
inside of the fenderwell/trunk wall.
If the trailing arm was notched (about .5") and the fender
well/trunk area was moved towards the car centerline,
I think these would fit just fine. This approach would
be similar to how the hotrod guys "tub" a car to put
big fat tire on it without flares.
Control arm interferance
Rear view of car
Tire hitting body (trunk area)
'73 914, 1.7, with Boxster transmission in the future?
Old 08-14-2002, 02:01 PM
Jim Smolka's Avatar
I have a set of 225x16 on 8" phone dials to test fit. I plan to use longer wheel studs and a 3/4" spacer. Looks like it should fit though...
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 08-14-2002, 06:25 PM
jabb's Avatar
Your ride hieght looks high in the rear.... Which is helping your outside clearence.
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 08-14-2002, 06:38 PM
