marksgerman914's Avatar
Engine number on 74 2.0
I went to look at the serial number on the engine of my 74 2.0 and i found that there is a hose running in the area where its supposed to be . The hose attaches on the drivers side of that area. Does any body know what that hose does? And why it is there? The number is under it. And I dont want to move the hose without knowing what it does. I dont want to screw somthing up.Also, there is a number on the case in front on the battery side that starts with a Zu.
mark s.
74 914 2.0
2001 vw jetta wolfsburg
79 vw rabbit
Old 08-18-2002, 05:33 PM
bowlsby's Avatar
The hose attaches to the flashback valve, if stock. Just pull it off to see the number and push it back on.
Old 08-18-2002, 06:37 PM
914 Geek
The "flashback valve" (hey, it's what the manuals call it!!) is an odd-shaped "T" connector with a screen in it. The screen acts as a flame trap in case of backfires. The other end of the hose in question connects to the right-side cylinder head, and is part of the Positive Crankcase Ventilation system.
What Mark's German said--pop it off, and then pop it back on again. If it is cracked, replace it.
EDIT--
Oh, yeah. The thing that starts with "ZU" is "ZUNDFOLGE 1-4-3-2". (Or close to that.) The word is German for "firing order", and it simply denotes the order in which the cylinders fire.
--DD
Old 08-18-2002, 09:16 PM
