911 Valve Adjuster Nuts
I am away from my engine for a day (at work) so I cant look but want to order parts today. Please help if you can.
What is the pitch of the 8mm valve adjusters? Standard, 1.25 or fine, 1.0? For reference, 6mm screws have 1.0 pitch. All of my nuts have mangled corners. I dont think that this is uncommon. Because the nut is so thin, its hard to get a wrench on it squarly. Therefore, I would like to use a Hex Nut as opposed to a Jam Nut. It would add a gram or two to the system but how much would that matter anyway. I could make up for it by cutting down the adjusters, they are much longer than necessary. Thanks for checking, Another clue, it is the same as the D-Jet head temp sensor threads. |
