Crank Case Ventillation
I have searched the threads and can't find my exact issue (I am also new here).
![]() attached should be a stock hose diagram for a 1973 with FI. I have a stock 1973 1.7 with dual carbs and need to know what I need to change on this diagram for all the hoses. Can anyone scratch out a solution for me? Thanks in advance from a newbie. |
The hoses from the head vents #6 go thru the antiflashback valve #13 and then to the air cleaner #1. The hose from the oil breather #2 goes to the plenum #4 on the FI system.
You can tie all of them to a breather can or put #2 into a breather box with a return to the crankcase. The head breathers can go to your air cleaner on the carbs with an adapter fitting. The vacuum hose from the distributor #3 (retard) would have to go to a port on your manifold or a port below the butterflies on your carbs. The other vacuum line from #3 is an advance function and can be left open (not connected).
Ron Meier Backyard Shadetree Mechanic 1974 914/6 conversion with 2.7L (The Grey Ghost) 1973 Chalon with 2.4T MFI (Schlitzalom) All my 4 cylinders are gone
Thanks. I have been considering a breather box. Where would I connect the return to crankcase at?
Sorry, you can't really connect a return hose. Route it to a catch tank and drain it periodically.
thanks.
Well, yes you can.
My breather can kit automatically drains back - so it never needs emptying, and it supports the "green" option of routing the vapors to the air cleaners.
Chris Foley CFR-Tangerine Racing Products, LLC - 914 Products and Services |
