-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Dimensions of stuff (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/78834-dimensions-stuff.html)
hitbyastick 08-27-2002 11:28 AM
Dimensions of stuff
Does anybody know where I can get the blueprints, or diagrams for fender flares, or various other parts. The reason Im asking, is because I work in a factory where we do everything with steel, and sheet metal, and we have the machines and tools to form everything. So if I had a diagram of exact dimensions, I could manufacture me some steel fender flares. I might need to buy a set and duplicate it or something. Just a thought ....SmileWavy
mike mueller 08-27-2002 12:49 PM
If the shop is "modern", your best bet is to buy a set of 'glass flares and copy them with the CMM. The newer and better CMM's
(Cordinate Measureing Machine) will actually draw the part for you as you measure it from point to point.
chibone_914 08-27-2002 02:43 PM
Good idea, but I'd use a steel set of flares to use as a master set. Fibreglass is close, but still is not as good as the steel units. If you're going to go through all the trouble and expense.
Just my .02 cents
dave blackburn 08-27-2002 03:03 PM
I have one extra right rear fiberglass flare that I will sell for cheap if you would like to use it.
