-6 Oil Tank Installation Template
Does anyone know where I can find information on hole locations and sizes to install an OEM -6 oil tank in a 914 conversion project? I am aware that every 914 supposedly had dimples stamped into the bulkhead denoting the center of each hole needed to install the oil tank. But, I also need to know hole sizes; and, there has been some comments made that the dimples do not include every hole needed.
I want to punch/drill all the needed holes before I paint the car, which will be happening shortly.
Thanks in advance for any leads you can provide.
Ernie
98 993 C2S - Arena Red/Beige
76 914/6 3.2 Conversion - Estorill Blue/Coral Red
Old 01-24-2014, 09:59 PM
RETIRED
Joe Bob's Avatar
I've always just cut the holes based on the sizes of the fittings. I use a caliper, measure and then go the next bit size larger. I use cheap HF hole cutters on a drill motor.
2012 ML350 3.0 Turbo Diesel
Old 01-28-2014, 10:11 AM
Thanks for the response. I was interested in the template that allows me to lay out center for each of the holes. Do you know where I might be able to source the template?
Ernie
Old 01-28-2014, 02:31 PM
RETIRED
Joe Bob's Avatar
Never seen one.....that why I suggest a little wiggle room on the hole size. Plus it assists in get the thing in there. It's a tight fit.
Old 01-28-2014, 02:36 PM
JEM JEM is offline
JEM's Avatar
i think auto atlanta has what you want
jerry
JM Motorsports
Custom Paint & Bodywork
81 911 SC ,black
73 914 V8 LS1
83 Audi Ur-Quattro,black
Old 02-01-2014, 02:27 PM
hardflex's Avatar
Aren't there dimples on the body panel that marks the center of the holes?
72 914 2056: 74 9146 2.2: 76 914 2.0
Old 02-01-2014, 02:59 PM
