Pertronix Ignitor II - Car won't start
Last night I installed the Pertronix Ignitor II ignition module and the Flame Thrower coil. The car cranks but does not start. I had already changed the plugs, wires, cap and rotor, as well as the fuel filter.
What should I check in troubleshooting the problem? Thanks. |
Check for spark. Use an extra plug taped to a ground, and look to see if there are sparks when the starter cranks. If not, you may have blown the Pertronix.
If there is spark, check for fuel. --DD |
I checked and had no spark. If I blew out the Pertronix, could I have done any additional electrical damage or do I simply replace the Pertronix or go back to points and condenser?
Thanks everyone. The Pertronix Ignitor II I received is part # 91847V, which is for a vacuum advance distributor. My Bosch 009 distributor has mechanical advance and should be using module part # 91847A. Will this cause no spark and the engine to not start? Thanks again.
Is the magnet assembly hard down on the shaft,they are very tight to get on with the Pertronics one,less so with the Hotspark kit. If you still have the vacuum dizzy you could try that with the kit ,it will preform better than the 009 if you are running carbs for instance,the advance curve is more suited to the T4 motor. Did you try to start with the old system installed? |
| All times are GMT -8. The time now is 04:18 AM. |
