Fiberglass bumpers
I hope to take delivery of my first 914 in the next week or so. It has been hit in the front and needs a fender repaired, maybe a hood, and the front bumper has been pushed in. I've always loved the 914's but hated the big bumpers on the 75 and 76 models. Do the fiberglass ones fit without any of the rubber pieces needed on the top like the early bumpers?
Also, what's you suggestions on fixing the front drivers fender?
Thanks,
Rick
Old 03-30-2014, 11:09 AM
Anyone?
Old 03-30-2014, 02:02 PM
Are you buying a 75-76 914? if so, there are some differences on the fender corners when fitting fiberglass or metal/upper rubber strip bumpers. Not exactly a bolt on
1970 914-6 street"evil cockaroach"
1970 911 Spyder
1970 911S Conda
Old 03-30-2014, 02:49 PM
Fiberglass bumpers
It's a 75 and I am hoping for something that is a direct bolt on without and rubber parts.
Thanks,
Rick
Old 03-30-2014, 02:54 PM
There is no such one piece bumper being produced , that fills up the space on the fender corners. We have a pair of new 914 GT front and rear one piece bumpers with molder fake rubber top pieces. The ends would have to be modified to fill the gaps
D
1970 911 Spyder
1970 911S Conda
Old 03-30-2014, 03:01 PM
Fiberglass bumpers
Thanks for the reply. Any pics, and what is the recommended way to fill the gaps?
Old 03-30-2014, 03:12 PM
a 914 GT glass front bumper might be the ticket, has an air scoop for an oil cooler (or radiator is you go V8) they also make a read GT glass bumper.
Old 03-30-2014, 03:49 PM
Vintage Owner
Jack Stands's Avatar
You might want to try checking Getty Designs as they have fiberglass front bumpers (albeit with an oil cooler cutout). Also, contact Brad Mayeur at 914Ltd. ( 309-694-1797) as sometimes he has some used parts and is another valuable resource in the Midwest for all things 914. Also, Garold Shaffer in Portage, IN may have the parts you're looking for. He often posts on the 914World website.
Good luck on your project.
84 Targa
70 914-6
73 914-6 2.7 conversion
75 GMC Motorhome
Old 03-30-2014, 05:37 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
There is a FG repro of the late-style bumpers. It probably can be fitted without surgery.
If you change to an early-style bumper, you will need the rubber across the top of the bumper as well. There are FG versions that also include a copy of that rubber part; that might be an option.
You will have to do some cutting to fit early bumpers on a late car. The late car has lips that stick out from the sides of the fender to hook the rubber bumper cover on, and the front of the front opening has a lip across it to hook the top of the rubber cover onto. Those will all need to be trimmed or removed for the early bumper to fit decently.
Plus you will need to drill mounting holes in the fender wells (for the front) and in the rear panel (for the rear). And you'll need to cover up the larger holes where the late-style mounts go through the front and rear panels.
It can definitely be done; it has been done dozens of times. But there is some work to do.
--DD
Old 03-31-2014, 09:18 AM
TR TR is offline
TR's Avatar
The big rubber bumper is probably the reason why your car is salvageable.
Old 03-31-2014, 12:28 PM
Thanks everyone for the replies. Anyone know where pics of installing earlier bumpers on a 75 can be found?
Rick
Old 03-31-2014, 03:07 PM
TR TR is offline
TR's Avatar
There is a whole bumper backdate thread on 914 world I think.
Old 03-31-2014, 06:32 PM
Thanks again for the replies, the 914World write up was excellent. Also, I got a PM from someone on this topic that I inadvertently deleted, can you please resend?
Thanks, Rick
Old 04-01-2014, 01:43 PM
I said I got a set of FG bumpers cheap that could be made to work.
Old 04-02-2014, 06:15 AM
