-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Rotor width???? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/80396-rotor-width.html)
dave blackburn 09-11-2002 10:00 PM
Rotor width????
Can anyone tell me the width at which a 75 914-4 rotor should be discarded and the width it may be turned at? My front rotors measured 10.1mm (0.398") before I got them turned today. Will they still be thick enough to prevent warping? I am also doing the bmw brake upgrade if this will affect it at all. Thanks, Dave
philinjax 09-12-2002 04:58 AM
Dave,
I think every 914 owner ought to have a copy of the Haynes
manual. Page 108 has all these specs.
Your front rotors are going to too thin.
Phil
Zeke 09-12-2002 09:17 AM
You can turn them one more time if they are not bad and you start with 11mm. 10mm is the limit according to Haynes; Phil is correct on that. I'm surpriised that you found someone that would turn them past 10mm. IIRC, the min is stamped on the rotor.
