Driver side front running light doesn't work
I can't figure out what is wrong with the signal/driving light on driver's side. the turn signal works but the driving light won't come on. It isn't the bulbs. I measured the voltage at the plug and it doesn't seem to be getting power. When I pulled of the cover, there are 3 wires in it. One is brown(ground), one is black(connected) and one is white (which isn't connected). I don't see anything to connect the white wire on the bulb plate. Any ideas before I tear apart the other side to see what's going in correctly on that side?
Never mind, I see the issue. A broken wire inside where the bulb is housed. Any one got ideas on where to buy the wiring or housing for the bulb?
light
I believe you are asking where to get a new turn signal bucket with socket and all lugs. Post in FS--WTB. Some of us have these.
Gary |
Thanks for the tip Gary. I think I only need the socket. The wiring is fine and so is the bucket. I only need the plastic piece that connects the wires to the bulb.
| All times are GMT -8. The time now is 11:17 PM. |
