tail light connections
would someone post the wire color-terminal connections for the rear tail lights. i can't follow the haynes or the pelican color diagrams, or at least the info is incomplete.
i have these 5 terminal identifications on the taillight housing: 31 R RF 54 58 i have these 5 wire colors: brown black/brown grey/brown grey/red black/yellow for the right rear tail light, i can tell from the PP color schematic that bk/yw -> 54 gy/rd -> 58 but i can't find the others. i did record the connections before i removed the wires but i don't know if my lights don't work because of the corrosion (now cleaned) or if they were misconnected. many TIA. |
Your in luck. I just did this a few days ago.
Left side: RF- gray/brown 31- brown 58- white/black 54- black/yellow (two wires) L - black/white Right side: R- black/green 31- brown 58- white/red 54- black/yellow RF- grey/brown Note: first color is main insulation color, color after / is stripe. Look closely at the white/red and grey/brown as they can look identical without good lighting.
'73 914 (Renegade V8 conversion) |
many thanks...WE HAVE STOP LIGHTS!!!! who would have thought you'd have to adjust the brake light switch! the things they (haynes...lash) don't tell you.
like: to remove the reset button on the shaft of the cable to reset the trip odo...... there is a set screw tiny-tiny-tiny set screw.. thanks again (now if i could just fix the horn...) |
sorry Lash, i stand corrected. brake switch adjustment on pages 254-255
