-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Transmission sensor? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/808366-transmission-sensor.html)
lancia71 04-26-2014 02:05 PM
https://farm6.staticflickr.com/5222/...43718ff3_o.jpgHi - I recently purchased a '73 914 2.0. I am in the process of disassembling the car. Preparing for the engine drop, I saw a sensor sticking out of the gearbox, just behind the left rear axle.
What is it?
https://flic.kr/p/nn3rb4
Dave at Pelican Parts 04-26-2014 02:45 PM
Back up light switch. When you put the transmission into reverse, a pin pokes out of the transmission into the switch, and shorts the two wires together. That is used to power the back up lights.
Those wires are added on--the sensor itself may have been messed with on your car. The stock ones basically have bullet connectors that push into the holes in the switch.
--DD
lancia71 04-27-2014 07:54 AM
Thanks for quick answer Dave! I'll add it to my to-do list and check it out. Lots of 'custom' wires on this car and the parts list keeps on growing and growing...
frank 04-28-2014 06:37 PM
I am hijacking this thread... sorry in advance.
My reverse sensor is functional... I bench tested it but in real world settings it fails to turn on the reverse lights... it seems that the plunger is either not long enough or the mechanism that pushes on it isn't pushing far enough.
Any thoughts?
Dave at Pelican Parts 04-28-2014 08:06 PM
The plungers can wear. I have heard of people fabricating new ones--even of people using an old drill bit as a new plunger, as long as the length was right!
--DD
frank 05-05-2014 01:15 PM
--DD
I fabricated a plunger from a rotary-tool bit, I even cut in the groove for the c-clip. it fit PERFECTLY. Now I have reverse lights for the first time in over 17 years!
Thanks for the idea!
