Web cam+carbs= which distributor?
I know this has been discussed to death, but does a stock 2.0 dizzy perform better than a 050?
I don't know about performance between the two ( probably the same) but if you already have the stock one use it and save the money.
Geoff (atleast you aren't asking about the "high performace" 009 distributor) |
If you can't/won't put advance and retard fittings onto the carbs, then the 050 is definitely better than the stocker. If you can put the fittings, they are probably pretty close. If you've got the money, the Mallory jobbies (very adjustable!!) are supposed to be the absolute best distributors. See several threads on the Shoptalk Forums BBS http://www.shoptalkforums.com for details on those.
--DD |
| All times are GMT -8. The time now is 07:23 PM. |
