Can U and should U Lower a 914 ???
Curious if U should lower 914's like they do 911's,.I dont really see a reason to lower one But ??? Thanks Frank
Old 05-02-2014, 05:06 PM
Groucho Marxist
Tobra's Avatar
What are you going to use the car for, where are you going to drive it?
"Keep your eye on one thing and one thing only: how much government is spending, because thatís the true tax ... If youíre not paying for it in the form of explicit taxes, youíre paying for it indirectly in the form of inflation or in the form of borrowing."
Milton Friedman
Old 05-02-2014, 06:07 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
You should if you like the way it looks. Especially the front; it seems that Porsche tweaked the front ride height to a nose-up attitude to comply with US bumper height laws.
Lowering can help cornering grip if not taken too far.
It makes it a lot easier to scrape on bumps. (Scraping the bottom of the car on the freeway is a "Depends Check", let me tell you.)
It can make it harder to get in and out of. It can become more of an issue as we get older.
The front ride height can be changed by tweaking the torsion bar adjusters, just like on a 911 front suspension. For the rear, you will have to replace the springs and/or the spring perches.
--DD
Old 05-02-2014, 06:39 PM
Yea,..I thing it would look nice a little lower,..Good Thanks Dave,....Tobra...just around town,..and weekend trips...I do think it needs dropped a little,...Thanks
Old 05-02-2014, 07:21 PM
no reason to drop the rear but the front end is usually set way too high. Pretty much like most 911s . Just need to set it how it looks good to you. depending on wheel and tire size and the overall look
Old 05-03-2014, 04:37 PM
Cairo94507's Avatar
I would think the front coming down 1.5" and the rear about .5" would be good. Depending upon where you live and the tires you intend to run, maybe 2" front and 1" rear.
2016 Audi S3 DD
2010 997.2 C4S 6 Speed
Old 05-04-2014, 05:31 AM
I thought I posted to this question yesterday, but it's not here. If you alter the front ride height, you MUST align the car. If you go 1.5-2 inches, you're going to have to fix the bump steer issue by spacing the steering rack down. This NOT a simple drop-it-and-drive-it procedure. Trust me, I can tell you from experience that you can destroy a set of front tires in less than 200 miles ................ Along with lowered ride height, you get lowered ride quality. The lower you go, the worse it gets. If you like the rock-hard ride of a slammed Honduh or a dump truck, that might be OK. If you have a wife or significant other that travels with you, it could become a problem REAL fast.
The Cap'n
Old 05-04-2014, 01:18 PM
Mine is lowered... It makes cornering feel like there is no corner. It has been that way since I purchased it and I like it. I think I need new shocks though. I can feel a lot more of the road but again I think new shocks will help with that. I also know not to drive through pot-holes and take it easy over speed bumps. I avoid road debris too.
I very much like the look of a lowered 914 but as Dave mentioned, lowering makes it a little harder to get in and out. It is much easier to get in and out with the top off though. I just fall into it and pull my self out. I am not yet too old for it to be a problem but my Dad would probably complain.
Old 05-05-2014, 12:52 PM
Frank ,...Can I ask what the fender to ground measurement would be 24-26 "...Maybe Thanks FM
Old 05-05-2014, 02:45 PM
Resident Electrician
Mike Bellis's Avatar
Mine is lowered. Bilstein shocks front and rear. Very little bump steer.
This pic is on Mulhulland Hwy in SoCal during a PCA event.
Current Project: 73 914, 1.8t, ~300hp, 930 Brakes, Roll Cage
Past Projects:
69 911, converted to C2 wide body cabriolet 3.2L
72 914, Ford 5.0L V8 EFI
Old 05-06-2014, 05:38 AM
I am at 23" in the front and 22" in the rear. I measured from the floor to the bottom of the fender lip. Air pressure could change these measurements.
Cisco
Old 05-06-2014, 09:39 AM
Thanks Looks Great,...I always say they are the best handling cars on the plant,..I dont know of any other car except for maybe a lotus elite,..But on comparison,..on price and reliability
Old 05-06-2014, 05:28 PM
I like the looks of Frank's 914 re. the ride height. Would like to set mine up the same way. Any recommendations on a shop in the Southern California area? Thanks.
Old 11-28-2016, 12:04 AM
Emo993's Avatar
+1 Frank, that looks great. Best, Mark
Old 11-28-2016, 12:28 PM
Banned for Life
RSBob's Avatar
Lowered but not slammed.
Rick S, '71 914 3.0, '82 911SC EFI, R Gruppe #309
Old 12-17-2016, 08:18 PM
jmz jmz is offline
jmz's Avatar
much too Low for the street but works on the track.
Jay
'74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'80 911SC Weissach 3.2 Short Stroke Hot Rod
'68 SWB 911T build in progress -The Rat
Old 12-19-2016, 04:26 PM
Choice depends on the "look" you want and use (i.e., autocrossing?)...mine is lowered about 2", running on 14x5.5 rims and 205-60 tires, has 914-6 GT brakes and suspension, front and rear sway bars, bump steer kit and turbo tie rods installed. Since there is only about 6" ground clearance, care has to be taken with speed bumps, steep angled driveways and sidewalk curbs when parking. Since you are almost sitting on the pan compared to a 911, getting in and out with the roof on can be a bit challenging...especially if you are 6'4".
Old 12-23-2016, 01:40 PM
