-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Square sway bar into round bushing? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/810174-square-sway-bar-into-round-bushing.html)
The Glademister 05-07-2014 07:12 PM
So I've got the OEM front sway bar cleaned up, drop link bushings replaced and ready to install with Weltmeister Factory Performance Sway Bar Bushing PB-006. That bushing is a harder material than I've worked with before and I don't see how that's going to be pushed over those large square ends on the bar. Anybody got a tip?
http://i1336.photobucket.com/albums/...psjnxpihmi.jpg
The cap'n 05-07-2014 07:45 PM
Push the bushing on the shaft before you install the caps. Significant force may be required, even if you use a good silicone paste lubricant.
The Cap'n
Mike Bellis 05-07-2014 09:14 PM
Boil the bushings in water. Take the pan off the stove and into the garage. The water will soften them up for install.
The Glademister 05-08-2014 04:21 AM
Thanks gents! I suspected boiling would soften the bushing. A little dish soap might help lubricate also.
Joe Ricard 05-08-2014 08:58 AM
You are going to want to grease with Lithium or something similar. Fitting with grease zirk will go along way to keep that bar from sticking.
