1975 2.0L Relay Board to Coil Wire question
Hi all - '75 2.0L - there are 2 wires that originate from the T12 connection on the relay board that route around (behind) the air manifold and come from the rear towards the distributor - on the right side under the intake tubes. One is a large black wire and one is a smaller black/purple wire. I believe these wires go to the coil but I can't see from the wiring diagram which wire goes to which terminal - the diagram shows the coil terminals as "1" and "4" which means nothing to me. Can anyone help me with these 2 wires?
TIA
Old 05-24-2014, 07:40 PM
1 is for the points (-), 4 is power (12v+). These are standard German designations. The thicker black wire is 12v+, the thinner black/purple wire is for the tach.
The Cap'n
Old 05-24-2014, 11:21 PM
