Brake hoses
I am rebuilding my factory 914-6 brakes and found that the braded steel line dont fit through the tab on the strut.What do they want you to do drill a bigger hole in it to makk it work.
Also coud someone tell me if the pins that hold the pads in are the same on a four banger or can I buy some some where..
Old 09-21-2002, 02:15 PM
Brad Roberts's Avatar
Dumb question that will piss people off... but...
Where did you buy the brake lines from ??
The ones I use (notice I didnt say sell) fit just fine.
The pins for the rear calipers are the same.. the fronts will require you to get some from a 911T.
If you need too... you can use a Unibit to enlarge the hole for the brake line.
The ones they sold you are for the 4cyl cars that use a locking spring plate. The ones you need use a U shaped piece of metal to keep tension against the line.
B
Old 09-21-2002, 06:11 PM
I bought them from Vertex.Had a bad time dealing with them.
Old 09-22-2002, 06:10 AM
mskala's Avatar
Are you sure they didn't give you the late-model version? The 70-72 lines are different.
Mark S.
'70 914-6
Old 09-22-2002, 07:59 AM
Never left, but not right
Zeke's Avatar
Went thru the same deal. I turned the one end down on the lathe. Don't enlarge the hole, it makes your existing clamps, brackets and c shaped spring impossible to use as intended.
Old 09-22-2002, 08:13 AM
