-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   1974 914 No Reverse (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/814926-1974-914-no-reverse.html)
triceraclops 06-06-2014 03:24 PM
1974 914 No Reverse
I have a 74' that simply will not shift into reverse. Im fairly new to Porsches and was hoping you guys would have some suggestions. Thanks!
Dave at Pelican Parts 06-07-2014 04:26 PM
How's first gear? What about 2 and 4? If either of those also have problems, you may need to adjust the shift linkage.
A problem with first and reverse could also possibly be due to a clutch that is not releasing all the way.
If it really is just reverse, it could be something inside the transmission. That is much less likely, though.
--DD
