best/least expensive after market F/I system
for a 2.0 big four engine,....Thanks agin, Frank
Old 07-11-2014, 09:32 PM
914 Geek
Least expensive is Megasquirt. But you have to solder the board together yourself, and program it, and come up with the intake and injectors and so on. There are places that will solder the thing together for you, and some that will program it for you, but of course those add to the cost.
SDS (Simple Digital Systems) makes a simple system that is easier to install. I think you still have to provide the manifolds and throttle body.
Most of the others I can think of are rather more expensive. And you still have to deal with the intake manifolding and such.
Oh--CB Performance has an EFI setup that includes independent throttle bodies. That's one instance where you don't need to work out the intake manifold.
Or slap a set of Webers on there.
Any way you go, you'll need to invest some time and $$ into tuning.
--DD
Old 07-12-2014, 09:53 AM
Resident Electrician
Mike Bellis's Avatar
Megasquirt is the cheapest ECU but not the cheapest to install since you will have to fabricate everything. If you have the intake from the stock FI system you can reuse it.
The CB system is bolt on and includes most of the parts you will need.
SDS is mostly ECU and sensors so you will need to fabricate the intake or reuse the factory FI system.
I think the CB system is the best value if you are starting with nothing. If you are resourceful, the Megasquirt would be number 2 on the list. You will also need fabrication skills for either the MS or SDS systems.
Current Project: 73 914, 1.8t, ~300hp, 930 Brakes, Roll Cage
Past Projects:
69 911, converted to C2 wide body cabriolet 3.2L
72 914, Ford 5.0L V8 EFI
Old 07-13-2014, 07:40 AM
bowlsby's Avatar
Maybe I missed it but a 2.0L is not a 'big four'.
If that is the case, either of the factory D-Jet/LJet FI systems can be made to work, the D-Jet is out of the box and would be the least expensive.
Old 07-13-2014, 08:06 AM
Having just gone through this on a 911, the Megasquirt is horrid.
You can easily make ITB's out of motorcycle throttle bodies on the cheap. Suzuki I find is best, and they use Keihin injectors... which are prevalent in road cars like the Honda S2000 (which is a correct injector for the 3.0-3.2 911.
When I do this again, I'll use the Electromotive Tech GT.
Current: 914/6 GT Conversion, Cayman
Old: Many PCars + Formula Racecars
Old 07-14-2014, 06:33 PM
porschetub's Avatar
Second that,the setup drives most people nuts,did see a system a while back that used GM parts in the setup,could be programmed for larger displacement and easy/cheap parts supply for maintenance,was around $1200 from memory,sorry can't find the link but liked the idea of a fully mapped upgradeable system.
Featured modern TPS,sensor,injectors,AFM ,etc and the previously mentioned ecu.
Will try and find link if the guy still makes them?.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 07-16-2014, 01:51 AM
FWIW, generally speaking, the terms "best" and "least expensive" rarely describe the same item.
The Cap'n
Old 07-16-2014, 08:36 AM
Thanks Porschetub that would be great,...and Yes Cap'n I understand,...but sometimes you get lucky and the knowledge here is helpful,..if its not here its nowhere....Thanks Guys..!!!! Frank
Old 07-18-2014, 04:17 PM
Hell Belcho
Nostril Cheese's Avatar
Subaru or 911 engine.
Old 07-21-2014, 03:37 AM
