Help with parts needed for sideshift transplant
Preparing to install sideshift tranny in my '70. I have complete late type shift linkage and engine mount bar. Still need to get bolts for ends of bar and rubber engine mounts. Question: Do I need to get the two brackets for the engine end of the mounts? Or are the proper brackets already on the early 1.7 engine?
Old 09-26-2002, 07:52 PM
Brad Roberts's Avatar
You need the engine brackets and the cross bar brackets for the chassis from the 73 car.
You'll also need the adapter bushing for the firewall.
B
Old 09-26-2002, 09:03 PM
canna change law physics
red-beard's Avatar
Jim,
Is this the 4 or the 6?
James
James
Red-beard for President, 2020
Old 09-28-2002, 07:08 PM
Master plan calls for installing a sideshift trans (which I have) in my '70 4cyl, then using the 4 cyl. tailshifter as a transplant (no pun intended) into my 6, using the six end cover. If I sell the 6 first (it is for sale) I'll simply do the tailshift switch into the 4. As you know, the 6 linkage is a bit vague, the 4 is like a spoon in soup, though new bushings would probably help.
Old 09-28-2002, 07:18 PM
Oops. Sideshift switch into the 4.
Old 09-28-2002, 07:20 PM
