-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Is Elec Control Unit bad? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/820663-elec-control-unit-bad.html)
KPAX914 07-14-2014 12:56 PM
Help: Anyone I can't get this 1.7 L to accelerate? What I have done: all new ignition parts + coil and Pertronics module. Overhauled Dist ( cleaned lube advance weights). New F.I. wiring harness. Checked TPS, MPS, temp sensors-2.
When I disconnected TPS she runs with no acceleration. Reconnect TPS same prob.
Is this my ECU gone bad?
Desperate
bowlsby 07-14-2014 03:27 PM
Probably not the ECU. Keep looking...possibly a fuel delivery issue - kinked fuel line, clogged filter? Have you confirmed fuel pressure?
KPAX914 07-14-2014 06:34 PM
I will check the fuel system. Thanks for the info.
