where to get the Best car lift for a 914...????
I would like to get a used car lift or find a way to lift it up and move it around as needed.......Thanks Frank
Old 07-18-2014, 03:59 PM
Control Group
Tobra's Avatar
So are you talking about tire dollies, that you put under each tire and it lets you roll the car around, or an actual lift? You can get 2 pairs of tire dollies at Harbor Freight for around a hundred bucks.
Old 07-18-2014, 04:34 PM
True,...but yes, A actual lift,..i want at least 3-4 ft in the air without using the wheels
Old 07-18-2014, 05:21 PM
Emo993's Avatar
BenPak, very nice product. Works great with 914 and 993 Porsche's, and a few VW. Mark
Old 07-19-2014, 06:31 AM
Lifting, lots of options. Rolling it around once it is lifted. haven't seen anything that can do that, and that I would trust to be stable enough, other than maybe a full sized fork lift.
Robert
Currently Porsche less (but the wife has 2)
Old 07-19-2014, 07:26 PM
Emo ,..how much is a lift like that ???? Thanks Frank
Old 07-19-2014, 08:29 PM
Emo993's Avatar
I think is was $1,800 delivered. Not the cheapest, but one of the best scissor type. All are made in china even the BenPak. Larger BenPak (two post) are US made with highest standards. I've had it for five years, lots of auto work, timing belts, transmissions, brakes, works just great. When it lowers into the floor I do have a cover for it so I can drive over it. Also works great for an additional 4 foot by 8 foot work bench when up. Mark
Old 07-20-2014, 06:13 AM
ASE Master Tech - 35 yrs
larrym's Avatar
Arrow maxjax lift
discussed a bizillion times on all the forums - just google maxjax
mine cost $1800 delivered - you once could get them from COSTCO
It is perfect for 914 engine changes - nothing in the way - no rails, no scissors to work around
- and when you are done, just unbolt it & move it aside so the wife can get into the garage again
p.s. - my slab is 5" - 5-sack - and wire reinforced
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 07-20-2014, 05:15 PM
Hell Belcho
Nostril Cheese's Avatar
scissor lifts are kinda useless in my opinion. If you are going the MaxJax route, make sure your slab is thick enough to support it.
Old 07-20-2014, 05:43 PM
Thanks Guys ,... Ill ck them out......FM
Old 07-20-2014, 08:35 PM
