beatnavy's Avatar
Isolating Oil Leak
I've been getting some oil dripping on the passenger side heat exchanger for some time now. While it doesn't bother me when I'm driving, once I have the car idling in my driveway it does create a noticeable smoky aroma that not everyone in my family or in the neighborhood finds attractive. In trying to isolate the possible cause, it LOOKS like it's dripping on the heat exchanger near the warm air guide and in back of the oil filter, but I can never actually see the drip. I guess when I drive it blows it all the way back past the drive axles on the heat exchanger. I'm pretty sure it's not coming from the valve covers. Any other likely culprits? Oil cooler seals? The CV joints themselves (although I think it's starting up further). Here's a picture below (FWIW):
Old 07-20-2014, 12:22 PM
Chances are good its the oil pressure sender or the oil cooler seals.
Paul Woodbury
See my Rennport Reunion and old IMSA pictures here:
Old 07-20-2014, 03:21 PM
beatnavy's Avatar
Roger that, thanks. It should be pretty easy to see if the oil pressure sender is leaking, right? If not that, I guess I can try to replace the oil cooler seals with engine in car. It sounds like a lot of "fun."
Old 07-20-2014, 03:44 PM
King Broinyo
Nostril Cheese's Avatar
Check the pushrod tube seals first. They usually leak. Fix is Viton seals with a very light coat of Curil T in the bores.
Its easier to drop the engine than try to replace the oil cooler seals in the car. Using a motorcycle lift from Harbor Freight makes it way easy. It takes me roughly an hour to pull the engine/tranny. pull them both as a unit.
Spend a day, get some friends to help and some beer. Pull the tins and valve covers and seal everything up in one shot.
Old 07-21-2014, 02:52 AM
King Broinyo
And see that pulley in the above photo? Clean and lubricate it.
Old 07-21-2014, 02:53 AM
beatnavy's Avatar
Jawohl, good point. I will clean and lube the clutch pulley. Don't want any more shifting issues than I already have or have had.
Ok, so I was planning on pulling the engine at some point to do this. I just pulled a 1.8L a couple of weeks ago, and it wasn't too bad. I have NOT yet put one back in. That will be a new experience.
Thanks again.
Old 07-21-2014, 05:17 AM
King Broinyo
Thanks again.
Physically remove the pulley and put some grease on the shaft too. Re-adjust your clutch cable at the same time. If you still have the plastic clevis piece, ditch it for a metal one.
Old 07-22-2014, 12:01 AM
Was going to write "check oil filter seal" but guess you have done that already.
Lars S
Old 07-22-2014, 05:03 AM
porschetub's Avatar
All the trouble areas have been listed already,(pushrod tube seals leaks are very common) ,one thing I have done in the past is clean away all traces of oil under the engine with brake cleaner/engine degreaser.
Place a large white sheet of signage material or cardboard under the engine ,start it and bring up to running temp and you will normally find the location of the leak by looking upwards....has usually worked for me,cheers.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 07-23-2014, 11:24 AM
Could it be a leak coming from the transmission shift linkage? This is a picture just one of my leaks that I need to address. I don't have the heat exchangers but it looks like it would be directly above them.
I'm new with the 914, so I'm just trying a helpful guess.
1973ish 914 Race Car
1988 911 Targa GP White, gone back to the Fatherland.
2003 BMW M3 6spd
1976 Datsun 280Z BRE Tribute race car
Old 08-12-2014, 05:39 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Yes, it could be. There is a seal around the shaft where it goes through that console into the body of the transmission, and it can leak. There is also an O-ring around the console where it fits into the body of the trans, and that is a (much) less common source of leaks.
--DD
Old 08-12-2014, 05:50 AM
IME, transmission oil from the shift console doesn't leak onto the right HE all that much.
The Cap'n
Old 08-12-2014, 07:20 AM
beatnavy's Avatar
Agreed. Also, I have a tail shifter (much to my chagrin but hopefully changing at some point). I think I've seen seepage at a pushrod tube. Question: are those easier to change with the engine in or out of the car? I did my Karmann Ghia's with the engine out of the car, but once you have it out, getting underneath it can actually be tricky. I do intend to take the engine out at some point to do a few things, including the oil cooler seals, but that may not happen for a bit.
TIA
Old 08-12-2014, 09:47 AM
TIA
A pushrod tube seal leak may actually be easier to repair in the car, unless you have your engine on an engine stand. You really need under-the-engine access, which would be difficult with the engine on a cart, the floor, or blocks.
The Cap'n
Old 08-12-2014, 10:09 AM
beatnavy's Avatar
Thanks, Cap'n. I thought that might be the case!
Old 08-12-2014, 11:24 AM
Administrator
To replace the pushrod tube seals, you just pull the tubes halfway out of the head. That gives you access to both ends, so you can replace the seals easily there. And unlike a Bug (or 911) engine where the tubes are sandwiched between the head and case, the 914 engine's pushrod tubes slide through the head into the case.
--DD
Old 08-12-2014, 12:41 PM
