mike mueller's Avatar
Pic of "T" and braket that replaces Prop valve
Someone asked about mounting the "T" that replaces the stock proportioning valve. This is how I did it. I used the factory prop. valve braket and tweaked it a little to get it to work.
'73 914, 1.7, with Boxster transmission in the future?
Old 09-27-2002, 05:17 PM
anthony's Avatar
Where is the proportioning valve located? I'm going to need to install one soon.
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 09-27-2002, 05:19 PM
dave blackburn's Avatar
If you crawl under the car, the prop valve is located behind the drivers seat between the firewall and engine tin. You can't miss it. Dave,
75 1.8L
Old 09-27-2002, 05:36 PM
see the big hole in the picture?
that is where the shifter linkage comes out from inside of the car to go to the transmission.
Old 09-27-2002, 05:42 PM
anthony's Avatar
Thanx!
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 09-27-2002, 05:49 PM
Brad Roberts's Avatar
Too much work Mike.
You had to bend a 90 in that top line.
Feed the tee from the bottom with the "feed" line from the MC and let the 2 lines from the sides come into it naturally just like the original prop valve did. They reach just fine.
B
Old 09-27-2002, 11:43 PM
