2.0 Distributor
I have a spare 2.0 distributor into which I have installed a Compu-Fire breakerless ignition module. The distributor part number is 039 905 205 A and the distributor vacuum advance mechanism is marked 831 on the actuator arm. My question: Can this be used in my 1974 2.0 engine? Everything I've read indicates that the 74 2.0 actuator arm should be numbered 603. I believe the number 831 is from a 70-72 17. The distributor number indicates a 2.0 part. What are the differences in the advance mechanisms for an 831 versus a 603 actuator arm? The distributor in the car does not use the advance vacuum port. It is vented to the air. Everything I've read shows that to be correct. I would like to just remove this distributor and replace it with the Compu-Fire distributor.
Thanks,
Bob Soldani
Old 07-30-2014, 09:24 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
That distributor will work fine in a 74 2.0 engine. The vacuum retard (as you say, the advance is left disconnected) is pretty similar between the different versions used on the 914 distributors. For details on that, see https://web.archive.org/web/20000830123941/http://www.dgi.net/914/tech/distrib.html .
If you mean you want to swap in the 2.0 distributor with the Compu-Fire in place of your 2.0 distributor, it should work fine. If you're talking about swapping in a complete aftermarket distributor, the stock D-jetronic fuel injection will not work without the fuel injection trigger points down in the base of the distributor.
--DD
Old 07-30-2014, 11:10 AM
Dave, thanks for your input. I do intend to replace existing distributor with the Compu-Fire unit.
Bob
Old 07-30-2014, 03:57 PM
