-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Replacing trans driveshaft seals? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/824377-replacing-trans-driveshaft-seals.html)
pSquared 08-07-2014 02:56 PM
Small hypoid leak from both sides where inner drive shafts c.v.'s bolt to the tranny.
Looks like just unbolt c.v. and go in from there. Right? I'm assuming it's
Radial Shaft Seal 45 X 68 X 10 on both sides.
Does the trans cover lateral have to come off? Requiring replacement of
Gasket For Transmission Cover Lateral on both sides?
Are the seals available? Can't seem to find them mentioned or listed any where.
Thanks for any ideas.
p2
Joe Ricard 08-08-2014 08:59 AM
Yep drop inner CV joint and then the drive hub out of transaxle only held in with a spiffy easy to remove bolt. replace seal and re-assemble . recommend doing one side at a time. Side plate can stay on. not sure about seal availablity
The cap'n 08-08-2014 04:30 PM
999 113 183 40, Drive Axle Seal
Our host may have it, others, too.
The Cap'n
pSquared 08-09-2014 02:42 PM
Guys. Much appriciated.
p2
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
