Replacing trans driveshaft seals?
Small hypoid leak from both sides where inner drive shafts c.v.'s bolt to the tranny.
Looks like just unbolt c.v. and go in from there. Right? I'm assuming it's
Radial Shaft Seal 45 X 68 X 10 on both sides.
Does the trans cover lateral have to come off? Requiring replacement of
Gasket For Transmission Cover Lateral on both sides?
Are the seals available? Can't seem to find them mentioned or listed any where.
Thanks for any ideas.
p2
Old 08-07-2014, 03:56 PM
Yep drop inner CV joint and then the drive hub out of transaxle only held in with a spiffy easy to remove bolt. replace seal and re-assemble . recommend doing one side at a time. Side plate can stay on. not sure about seal availablity
Old 08-08-2014, 09:59 AM
999 113 183 40, Drive Axle Seal
Our host may have it, others, too.
The Cap'n
Old 08-08-2014, 05:30 PM
Guys. Much appriciated.
p2
Old 08-09-2014, 03:42 PM
