Dwell with Electronic Ignition?
Should I be getting around 50 deg. of dwell with EI/pointless dist?
My ancient Dwell Tach is indicating 20 - 25 deg. or so on the new
HotSpark 034 SVDA I have installed w/High Energy coil.
Not aware of any way to change or adjust, and nothing in the
install instructions I can find about that.
Am I barking up the wrong tree here?
Thanks,
p2
Old 08-20-2014, 08:35 AM
Your don't specify which unit you have but with a Pertronix you set the air gap and then time it. No dwell involved that I'm aware of,
Keith
Old 08-20-2014, 09:54 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
As far as I am aware, dwell is not relevant or meaningful once you replace the points with something else.
If the air gap is in spec, don't worry about the dwell.
--DD
Old 08-20-2014, 02:04 PM
Rods914's Avatar
I have used the Pertronic system for over 13 years in my 74 1.8 with stock fuel injection. I check the air gap once a year. No change no problem! Very low maintenance, which gives me more time to enjoy my 914.
Old 08-21-2014, 07:32 PM
Seems I need to learn new tricks
Come to find out checking dwell kinda 'pointless' with EI installed.
Good to know.
Moving on...woof.
p2
Old 08-22-2014, 07:47 AM
