woodman's Avatar
clutch cable replacement
Which clutch cable would you guys recommend as a replacement for a '75 1.8L car, Terry cable or any other? I heard that a 6er cable is a little closer fit, but I don't know for sure.
Thanks.
'75 1.8 -->1911
Old 10-02-2002, 08:11 PM
Brad Roberts's Avatar
Terry all the way.
We run nothing else in our cars (except hydraulic clutches)
B
Old 10-02-2002, 08:25 PM
3D914's Avatar
woodman,
I second Brad on the Terry cable. I've used these on the two running 914's I've owned, and never had a problem except the one cable I got with the rubber boot (for the fire-wall) on backwards. No sweat!
Enjoy,
Gerard
74-914 White - Soon to be a custom 3.2L Six 87-924S 2.5L Artic White - SOLD 74-914 2.0L Ravenna Green - SOLD
Old 10-02-2002, 08:58 PM
Stay away from my Member
campbellcj's Avatar
Go with the Terry. If you don't want to do that, get a factory OE cable (if you can find one). The cheap aftermarket ones are crap.
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2001 F150 Supercrew 4x4 | tow vehicle
Old 10-02-2002, 09:28 PM
is the cost warranted for the upgrade on the throttle cable too? the wet season has started. now i have an explaination for working on the car instead of the 2 acres.
kevin
Old 10-03-2002, 04:02 AM
woodman's Avatar
Thanks guys. I'm doing the throttle cable (Terry cable again??) and fuel lines to in a couple of weeks. I'm just trying to gather all the correct materials first. It's going to be a full on attack on that center tunnel. Oh yeah, shift linkage too, and while everything is out, I'll swab the inside of the tunnel with some rust preventative paint.
'75 1.8 -->1911
Old 10-03-2002, 06:32 AM
