Question Windshield wipers
My wipers on my 1974 914 will park at whatever position they happen to be at when I turn them off. Why won't they return and park at the correct position when I turn them off?
Old 10-04-2002, 11:29 AM
dave blackburn's Avatar
I had the same problem, I found I was missing a relay, It should be located in the front trunk on the drivers side between the fresh air box and the heater flap box, mounted on the back of a vertical support bar. On my 75 1.8 it was a large rectangle silver relay. If you have the same setup you might be able to add delay wipe in about a minute if the relay still works. Dave
75 1.8L
Old 10-04-2002, 12:37 PM
There is a thread on this subject if you do a search for "wiper return"
75 1.8L
Old 10-04-2002, 12:40 PM
