Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 914 & 914-6 Technical Forum
bernbomb914's Avatar
Question interion padding removel
How do you remove the pad behind the seats? I removed the screws on the bottom but it is still tight are there more fastners somewhere?
May all your shifts be true
Chrome Yellow 74 1.8 Beauty
black 74 1.8 project car
2002 Land Rover Disco
2002 Astro Van
32' motor home
Old 10-11-2002, 03:06 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
kellzey's Avatar
There should be four (I think) screws along the bottom.
Then you have to unscrew the handle for the trunk release.
(edited instructions due to excessive alcohol consumption. Mistakes corrected by a slap across the head from Brad)
Then you have to pull the bottom of the pad out and then pull the pad down.. The pad has metal tabs attached to it that sort of hook UP into receptacles on the firewall. This keeps the top of the pad from moving forward.
(end of edits)
Hope this helps.
Regards,
Qarl
Old 10-11-2002, 03:13 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Brad Roberts's Avatar
You have to pull out the bottom of the pad and then down.
The hooks go UP into the tabs on the chassis.
He will rip them off the cardboard backing if he pulls up on it.
B
Old 10-11-2002, 03:35 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
kellzey's Avatar
I stand corrected. Maybe it was the Jim Beam talking.
You're right.
I'll edit my original message.
Qarl
Old 10-11-2002, 04:04 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
interior pad removal
You're right.
Thanks for the info. bernbomb914
Old 10-11-2002, 04:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
