-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Help! Which fuse in what order in fuse box??? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/84176-help-fuse-what-order-fuse-box.html)
91420L 10-14-2002 04:48 PM
I just can not find definite information of fuse for my '73 2.0L EFI.
Which fuse(8, 16, 25) in what order from right to left in fuse box sitting on drivers seat?
Also are two fuses on relay board both 25amps?
Thank you for your help.
Dave at Pelican Parts 10-14-2002 05:07 PM
Fuse box fuses:
http://www.pelicanparts.com/914/technical_specs/914_electrical_fuses.htm
The rear-most fuse on the relay board is 25A. The other is an "on-board spare", I think. Not really used by anything.
--DD
91420L 10-14-2002 06:28 PM
Thank you!
Thank you!
I'll check mine tonight.
Takeshi
VARam1500 10-15-2002 04:55 AM
I think (since I'm at work) that my Clymer manual said the fore fuse on the relay board was for an optional rear window heater (defogger?) and went with that spare relay location for the same purpose.
--Case...
