-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   One more problem...tachometer bounce (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/842923-one-more-problem-tachometer-bounce.html)
911buff 12-15-2014 07:33 PM
When my 2.0 was running...the tach was bouncing rather vigorously. I replaced the points with an electronic ignition module and ever since, the tach bounces, violently at times. Is it the module and if so, can a resistor be placed in line quench the signal? Or is it controllable with an electronic ignition module. Thanks.
beatnavy 12-16-2014 02:21 AM
Here are a couple of good posts at the world. It sounds like bouncing is primarily caused either by a faulty tach or some fault in the coil, condenser, points, or even the little ball inside the dizzy. These articles talk about this including using a capacitor to dampen the problem if it's a faulty tach:
Tach Bounce
Tach Calibration
