1974 Porsche 914
ClausGraf's Avatar
Thumbs up Save the Porsche!
I will get the dimensions and materials used for the cradle.
I will incorporate some "lessons learned" during the cradle build.
Claus
Old 03-31-2015, 03:54 AM
1974 Porsche 914
ClausGraf's Avatar
Save the Porsche!
Here is a picture using the metal brake to fabricate the longs.
Old 04-20-2015, 04:20 AM
mark 74 carrera's Avatar
+1 on the body cradle plans
I have these projects in my future. I sure would like to learn from your experience.
Subscribed
Mark
Mark Isaak
1974 Carrera Targa - Light Yellow, Being driven
1974 Carrera Targa - Orange, Being disassembled
1974 914 - 1.8 liter, Delphi Green
Old 04-21-2015, 05:57 PM
Just stumbled on your awesome thread...what part of Houston?
~Sai
1988 930 stock, 1976 914-4 (Hibernating 17 yrs, 76K)
93 Acura Legend LS coupe 6-spd, Type II (DD)
95 M3 Red, 97 540I 6-spd Black
98 Landcruiser, 01 Rav4 (Wife's)
Old 04-28-2015, 09:50 AM
SegaGT's Avatar
I suspect there are many Porsche nuts in the area, even living in cul-de-sacs near churches!
My dream was always to get a 914 and missed my last chance back in the mid 90's.
Since then almost every car I love has sky rocketed in price to beyond what I could afford. Congrats on saving this car!!! Most would have scraped it.
Old 05-01-2015, 05:16 PM
Send a message via Yahoo to shoguneagle
Cool Saving a Porsche!
Glad to see someone doing ground level sheet metal work and fabrication. He is definitely right that you have to think all the way through each part segments as well as the total making sure everything is going right. A large chance of error is you do not have clarity of the work.
Have not done any auto sheet metal fabbing, but have via the aircraft world (both commercial and general aviation). I really like it because it is gives you a great feel and satisfaction to make a part correctly and have it fit properly.
A lot of Congrates!!! Job well done.
Would like to see the plans and measurements/materials for the dolly and the sheet metal brake. Very interesting applications!
Old 05-02-2015, 11:39 AM
This is shaping up to be one of the finer DIY threads I have seen. Keep up the good work.
Old 05-03-2015, 02:44 AM
1974 Porsche 914
ClausGraf's Avatar
Save the Porsche!
Thanks mark74carrera, just let me know how I can help!
sck007 I live on the west side near I-10 and Hwy6.
SegaGT I had to look at the picture again. It's not a church, it's a private catholic school. (It's amazing how much info you can get out of a picture.) And yes, most would have scrapped this 914. But, as the thread title says: "Save the Porsche!"
Thanks shoguneagle for the support! I need to make a sketch with the dimensions of the brake to share.
Thanks DrDIY for the support!
Claus
Old 05-06-2015, 04:36 AM
1974 Porsche 914
ClausGraf's Avatar
Save the Porsche!
I have uploaded a pair of videos.
When I got the engine running:
https://youtu.be/-a0rPjXoYo4
After running the engine many times (with lots of fuel injector cleaner) in the tank:
https://youtu.be/7fwghOzIIFw
Regards
Old 06-12-2015, 04:04 AM
Certified Porsche addict
The Glademister's Avatar
That engine sounds pretty good Claus. I noted in the second video idle settled right in but it appears you don't have a rev limit when you punch throttle. That's limited by the rotor cap and OEM is 5850 rpm. You can also get one for 6500 rpm. I highly recommend one or the other least your throttle cable gets in a bind wide open. Ask me how I know about that
Tennessee Region SCCA & PCA
Current projects - '85 928S, '87 924S, '82 931, '14 Cayman
Past projects - '72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '02 Boxster, '07 Cayman S, '73 914
Old 06-12-2015, 05:22 AM
Big difference!
Claus,
I got mine started about a month ago and it sounds just like your first video. The difference is remarkable. I am going to try the same thing. did you clean the injectors out/off the car or did you add cleaner to the the gas tank?
Mark
Mark Isaak
Old 06-12-2015, 05:57 AM
SegaGT's Avatar
Nice vids. I have always liked "dual-duals" on the type IV...
I was disappointed Pacesetter no longer made the Monza quad for certain applications they used to.
Old 06-12-2015, 03:53 PM
1974 Porsche 914
ClausGraf's Avatar
Save the Porsche!
Originally Posted by mark 74 carrera View Post
Claus,
Mark
Mark, I cleaned the injectors out of the car, and also ran the car with 2-3 gallons of gas and a bottle of injector cleaner.
Glademister, I don't have a rev limiter in the distributor.
Here is a picture of my daily driver and my 914 2 years ago:
Old 07-01-2015, 11:41 AM
1974 Porsche 914
ClausGraf's Avatar
Save the Porsche!
Here is what I have done to build the rear suspension mounts.
Old 08-10-2015, 08:30 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
You might also consider tying the outer pivot point to the firewall with a Heim joint or similar adjustable-length link. Your new parts should cut down on flexing pretty significantly, but there may still be movement between the pivot piece and the rest of the chassis, resulting in extra toe changes. I've seen that on a number of 914 racers, notably the ones from Hergesheimer in L.A.
--DD
Old 08-10-2015, 01:32 PM
1974 Porsche 914
ClausGraf's Avatar
Save the Porsche!
--DD
Will do Dave! Thanks!
Old 09-08-2015, 01:56 PM
1974 Porsche 914
ClausGraf's Avatar
Got more steel today!
Old 09-18-2015, 03:48 PM
1974 Porsche 914
ClausGraf's Avatar
Fabricating the driver's side longitudinal.
Old 09-19-2015, 03:15 PM
1974 Porsche 914
ClausGraf's Avatar
Save the Porsche!
After a few months, (and being unable to find a better tub at a good price near Houston) I continue on my journey. Now it's the driver's side longitudinal.
Sometimes when bending long pieces, my home fabricated sheetmetal brake doesn't get the bend right in the center section.
So I came up with this to make the bend have the same radius throughout the length of the whole piece (3.5 feet long)
Here is the inside long
Old 09-21-2015, 10:39 AM
1974 Porsche 914
ClausGraf's Avatar
Working on the 914. I think the drivers side console mount is in much better shape than the other side.
Old 09-27-2015, 01:19 PM
