RX-7 Oil Cooler Help
I am putting in an Rx7 oil cooler and need to know which of the fittings is the inlet and which one is the outlet, if it matters. I still have the stock thermostat in the cooler and a thermostat in the sandwich plate.
I saw a link to a page a few months ago that showed the different RX7 coolers but I can not find it now.
Unless I hear differently, I think that I will go into the lower fitting and out of the upper one.
Old 10-22-2002, 10:23 AM
Friend of Warren
This topic comes up quite often on the 911 board. Apparently there is an internal thermostat you have to remove. This thread should get you started: Radiator-style Carrera oil coolers
Kurt V
Old 10-22-2002, 01:22 PM
CamB's Avatar
That would be my cooler being discussed.
I didn't put it in, so I have no idea if it has a flow direction. Given I was told it has a pressure limiter in it, it may well have a specific flow requirement.
Cam
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 10-22-2002, 01:48 PM
Scott S's Avatar
I am very interested in this as well. I read the attached link/thread and have a couple of (hopefully) easy questions....
1. What year rx-7 has the appropriate cooler?
2. Is changing the AN fitting size a requirement or can you use the cooler "as is" (this is for a 4 cyl application)
3. Can someone explaing the internal pressure limiter feature and it's benefits/pit falls?
Thanks!
Scott S
- A pile of British stuff
- A growing pile of German stuff
... oh, and two Hondas - complete with car seats and pounds of fish crackers smashed into the carpet (and seats, and door pockets, etc etc etc....)
Old 10-22-2002, 01:59 PM
